450D Track tensioner stuck wide open. Tried using block of wood between track and blade, no results. since it is wide open it will not take grease. Question: Can the tensioner be removed without removing the master pin in the track and replaced? Thanks.
88 450D
89 JD 70 Ex.
201 jd skid steer
JD 450D Dozer 6way
450D Tension stuck.
Thanks for your assistance. I was able to remove and replace using a little heat and lots of patience.
Users browsing this forum: No registered users and 251 guests
