Oil filters for JD 2010 from napa?
Hey guys looking to see if any of you guys know what oil filters the JD2010 diesel takes from NAPA or other auto parts store. Also the same for the hydraulic filters, thanks a lot!!!!!
IH 500 6-day dozer , JD 2010 track loader, Ford 1900 4x4
spin-on or cart? what ser.# you have? oil cart is 1148 $13 spin-on is 1243 $10.......HLR trans filter is 7031 $27 or on eBay look for Baldwin pt92 $10 shipped .....on dozer the hyd. filter is metal and cleanable .....loader filter is JD only i belive
Its a serial #45xxx. Its a spin on engine oil filter. Ok great so I'll pick up the oil filter @ napa, the HLR TRANS filter on ebay and the hyd. filter from deere. Thanks a lot!!jtrichard wrote:spin-on or cart? what ser.# you have? oil cart is 1148 $13 spin-on is 1243 $10.......HLR trans filter is 7031 $27 or on eBay look for Baldwin pt92 $10 shipped .....on dozer the hyd. filter is metal and cleanable .....loader filter is JD only i belive
air filter should be 2222 NAPA $27.....if its not oil bath
Re: Oil filters for JD 2010 from napa?
Hi does anyone know what transmission and engine oil filter the john deere 2010 dozer takes? Car quest or Napa numbers.
You can find the John Deere filter numbers in the parts catalog and either of those stores should be able to cross the JD numbers. Sometimes there are filters that don't cross, but these do.
The engine oil filter is AH1111RT. Wix crosses it to a 51148 (NAPA 1148).
The two fuel filters both show as AT17387T, Wix crosses those to 33166 (NAPA 3166)
The filter in the transmission shows as AT21513. It does not cross to WIX, I believe you will find that one is a cleanable screen.
The filter for the H-L-R shows as AT15282. It does not cross to WIX, I don't know what that one is.
You can check NAPA and Carquest for them but I doubt you will have any luck. You can contact Lavoy, he might have those or a source.
Thank you very much
- jimmydiesel
AT15282 is NAPA 7031 WIX 57031.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
440 ICD 831 Loader
440IC 831 Loader
Interesting AT15282 shows as "This is a valid competitive part number and there is no replacement at this time." on the WIX site.
Checking 57031 0n the WIX site, it shows as discontinued.
Neither Baldwin or Donaldson cross either the JD or WIX numbers.
It is certainly worth asking about the 57031 (NAPA 7031) but it may no longer be available, once stock is gone.
- jimmydiesel
That filter does seem to be a unicorn. The nation wide NAPA inventory Shows 1 filter in Tampa Florida.
Part Interchanges
BALDWIN PT92
CARQUEST 84031
FLEETGUARD LF683
FRAM C1684
JOHN DEERE AT15282
JOHN DEERE AT15282T
KRALINATOR L731
NAPA GOLD 7031
WIX 57031
HASTINGS FILTERS PT92
Part Interchanges
BALDWIN PT92
CARQUEST 84031
FLEETGUARD LF683
FRAM C1684
JOHN DEERE AT15282
JOHN DEERE AT15282T
KRALINATOR L731
NAPA GOLD 7031
WIX 57031
440 ICD 831 Loader
440IC 831 Loader
440 ICD 831 Loader
440IC 831 Loader
Users browsing this forum: No registered users and 40 guests
