new guy...old 440
Kurt
new guy...old 440
Post by Kurt » Wed Nov 28, 2012 6:51 pm
Hi first post....I have a old 440 that I got when my father in law passed...motor was rebuilt about 10 years ago I think he went through the trans..but the final drive on the left needs help bad. when you pull the stick to turn left it stops the motor...I tore it apart and if I can post pics this is what I found....I think it needs bearings...is there a place with a parts list with prices....thanks Kurt
440 IC 445179
Post by NNAATZ » Wed Nov 28, 2012 7:26 pm
Sounds like a froze steering clutch, may need to pull the final and seperate the pak.
Kurt
Post by Kurt » Wed Nov 28, 2012 7:41 pm
Post by Lavoy » Wed Nov 28, 2012 10:29 pm
You need to pull the final off, there is no way you will get the case clean enough to reassemble otherwise.
Final bearing kit is $225, but you will likely need more than that by the time you are done, not including what you find in the clutch housing.
Axle will have to be machined where the seal rides I am sure. You will need gaskets, and shim packs, about $50.
I keep most or all of them on hand.
Kurt
Post by Kurt » Thu Nov 29, 2012 11:39 am
Ya I figured it would have to come apart more...the axle is the easy part...I plan on welding it up then turning it down on the lathe soon..would I be safe to assume the diameter where the seal ride is the same as where the bearing is pressed on?? that was my first plan of attack...other problem is the thing is 230 miles north of me, outside in the cold...and I only get up once a month. No turning back now ....Im sure the old man is looking down laughing at every time I touch it....
CELSESSER
Post by CELSESSER » Thu Nov 29, 2012 12:29 pm
Kurt,
Welcome to the board.
I agree with Nick that the steering clutch on that side is stuck and you stall it with the steering brake. Not uncommon with these old dry clutch's that sit for a while.
The old girl must be sitting somewhere in the eastern U.P.
Mine came out of the western U.P. My finals had a mix of grease and oil in them but didn't have the dirt/metal filings like yours.
You might have a hard time getting a smooth enough surface for the seal by welding and turning down. Also what will the heat do to the shaft ? You might see if a ready sleave might work better.
Not sure if the seal diameter is the same or a little smaller than the bearing seat diam.
When replacing that seal it requires a special tool(#JD230 (AM2774T)) that you can make or can buy from a member of this board(if he still has some). It is outlined in the service manual (SM-2023)which is something you WILL need to put this back together correctly. The manual is the best tool you can buy.
Have FUN! (don't add up the reciepts)
Chuck
notmeu
Post by notmeu » Thu Nov 29, 2012 1:20 pm
I 100% agree with you on the service manual. I learned the hard way by not having the manual when I ripped my finals apart the 1st. time! I would never attempt it without having one. There's alot of important setup information that need to happen during re-asssembly.
Kurt
Post by Kurt » Thu Nov 29, 2012 6:12 pm
Thanks guys....She is sitting in Kalkaska and was just west of Houghton Lake since 92 before that it was in Lake Orion since about 85..the father in law and his brother passed it back and fourth a few times .....No I really dont want to add up the $$ ...I mainly use it to plow snow and I know it would be cheaper to pay a guy to do it...but what fun is that?? Here is the paper work I got with it. Thanks again.
http://s1280.beta.photobucket.com/user/ ... sort=3&o=0
JWB Contracting
440 Fun
Post by JWB Contracting » Thu Nov 29, 2012 7:35 pm
You might want to consider buying a complete good final drive and then install new bearings and seals. Your's looks fairly rough. From the prices I see them go for in the states, I am guessing a complete assembly should be fairly reasonable and will get you going alot quicker than rebuilding and machining yours.
Yes, a 440 is a fine tractor for pushing snow. They are a nice little crawler. I still bring up the 440 ICD with a 6 way dozer that my dad sold in the early 90's. I may have to track down the purchaser and get it back.
I recently purchased a non-moving 440 ICD, starting to get excited about working on it over the x-mas break. It needs transmission and/or rear end work. I'm lucky that we have all the parts on hand, I think my dad has 2 or more complete 5 speed transmission / rear end housings if my problem is too deep in the tranmission to mess with. I want to have atleast 3 days in a row to work on it, could be too much of a task to finish in one weekend. Also need to find the correct non-deluxe seat that mine is going to require.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Post by Lavoy » Thu Nov 29, 2012 9:28 pm
Jason,
I have new repro standard seats available now when you get to that point.
Kurt
Post by Kurt » Wed Dec 05, 2012 12:23 pm
I found a pic of what a "good shaft" looks like....looks like Im going to have my work cut out for me...the seal surface is at a slight taper....I sure wish I would have dragged it home to work on it...
Kurt
Post by Kurt » Wed Dec 05, 2012 7:54 pm
well its the first step....I hope there is no pitting or voids.....
Post by jtrichard » Wed Dec 05, 2012 8:01 pm
if there is pits try to find a speedi sleeve ......i had a shaft welded up and turned it down it had pits but was a clutch throwout shaft and was only for bushing to ride on so it worked great
Kurt
Post by Kurt » Wed Dec 05, 2012 8:12 pm
The guy above had said to use a sleeve....I thought...Man that would be hard to make..Then after I got it welded up and showed a buddy...he said...they make a sleeve for that and they are not much money...then the lite bulb came on...Oh thats what he said...
Post by Lavoy » Wed Dec 05, 2012 8:24 pm
I have tried to sleeve an axle in the past, and the sleeve swelled so much by the time I got it to where the seal rides, it was real loose. The other problem was the splines left an imprint in the sleeve even after I got it to where it needed to be.
Users browsing this forum: No registered users and 37 guests
