Opening up the 420 - What to look for?
mulligan
Post by mulligan » Fri Aug 10, 2012 8:53 am
Hi Guys,
I'm going to be pulling the motor on my crawler to rectify the the issue of the main engine clutch not disengaging.
While I'm into it that far what else should I look into? It's a 5 speed with reverser and I'm unsure if the reverser actually works or not.
I have a deere service manual and that should help me along.
Willyr
Post by Willyr » Fri Aug 10, 2012 9:49 am
Since the engine is out, May as well inspect the ring gear on the flywheel. New pilot bearing and grease it before you reassemble it. I would even put a new rear main seal on as well. These are things you can only do with the engine removed.
Otherwise I dont know if you can rebuild the water pump but I would look into it. Maybe drop the pan, check for slop in your rods and crank mains. Rebuild oil pump.
There are alot of things that can be done when you take the engine off.
former owner of a 1956 420c
Post by Lavoy » Fri Aug 10, 2012 9:58 am
If you are that far, I would rebuild the reverser.
LarryD
Post by LarryD » Mon Aug 13, 2012 12:10 am
For sure if you want your reverser to work, now is the time to delve off into it while you have it broke.apart. Also if nothing else I'd check the front seal and bearing on the transmission. Both easy to get to with engine out as all you got to do is split it.again at the torque tube and tranny.
Post by Lavoy » Mon Aug 13, 2012 7:55 am
Keep in mind that the reverser oil is never changed, only kept at a certain level by the trans. If nothing else, they should be rebuilt just to get all the crud and filings out of the bottom of the case.
