Pipe Plugs
AllenS
Pipe Plugs
Post by AllenS » Tue Jul 10, 2012 5:27 pm
I drained the old transmission fluid out of the transmission housing and also the two final drives, and replaced with new 80-90 gear oil. While I was under there, I noticed two other plugs on the very bottom, towards the rear of the transmission housing. I took both of them out and am wondering what they are for. This is my 1955 JD 40C.
DukeofDeere
Post by DukeofDeere » Tue Jul 10, 2012 9:53 pm
These are for when you clean out your clutch packs.
Usually dry.
Sometimes oil leaks into there.
Duke
Pammark
Post by Pammark » Wed Jul 11, 2012 12:21 pm
I am not sure if it the same, but my 2010 has two plugs under the steering clutches. The inside tip had a 3/8" finger sticking up about a 1/2 inch. This is the brake drum allignment prong that rides in a slot on the underside of the brake band. It is used to keep the brake band from sliding sideways off the brake drum.
It should be dry inside. Excess water or oil coming out may indicate some future issues.
Mark
JD 2010 Crawler with Loader
AllenS
Post by AllenS » Wed Jul 11, 2012 12:51 pm
Yes, it's dry in there, I was wondering what they were for. This is my first crawler.
DukeofDeere
Post by DukeofDeere » Thu Jul 12, 2012 8:27 pm
If your top covers leak or come off you have a way to drain the water out.
Best answer I have.
Duke
Users browsing this forum: No registered users and 77 guests
