Lu47Dan
Post
by Lu47Dan » Wed Jul 04, 2012 1:16 pm
AllenS wrote:Willy, how do you link pictures to this site? Picasa is where I store my pictures if that helps.
Allen, to post photos here from Photobucket, you need to select the photo to post then click on the "Direct Link" under the "links" menu.
Then come back here and select the Img button in the menu bar above the dialog box, you will see this appear [ img ], paste the "Direct Link" next to it then click the Img button again to make this appear [ /img ]
Add text below the photo or repeat the posting of more photos.
Did you check the splines in the steering clutch driven plate?
Dan.
1956 420C with GSC blade
AllenS
Post
by AllenS » Wed Jul 04, 2012 1:30 pm
I don't have Firefox and I'm not sure what Photobucket is. When I transfer pictures from my digital camera, they go to My Photos. Then, I'll transfer them to Picasa. The pictures that I posted came from Picasa. I'm not sure why I wasn't able to provide individual links here. Picasa is nice because they won't show up so large. You can then click on the photo in Picasa and zoom in.
Lu47Dan
Post
by Lu47Dan » Wed Jul 04, 2012 4:29 pm
Photobucket,
http://photobucket.com/
I use Irfanview to resize photos.
http://www.irfanview.com/
it is pretty simple to use.
Dan.
Post
by Paul Buhler » Wed Jul 04, 2012 8:09 pm
Allen: Picassa organizes pictures stored on your computer. Photobucket is a web based photo site that allows you to share pictures with anyone anywhere by sharing a link to the photo(s) you upload. It is a free site and it is pretty easy to use. Use Dan's link and info to get started. Photobucket will walk you through uploading a picture or video. Good luck.
454BBGB
Post
by 454BBGB » Mon Jul 09, 2012 6:36 am
Update : pulled fibers and steels out cleaned and reajusted the pressure plate setting, reassembled , stick is not going back forward like a spring is broke , All good from veiwing when apart. now have a click when pulling back on stick .. Looks like around the area of the the brake linkage . Could the problem lie in the throw out bearing assembly ? Left side is perfect good pull and allows stick to go back foward . Case is coming back off . Getting really good at pulling case off .. Any input, I thank all in advance . Good day .
2 Lungs
Lu47Dan
Post
by Lu47Dan » Mon Jul 09, 2012 6:58 am
454BBGB wrote:Update : pulled fibers and steels out cleaned and reajusted the pressure plate setting, reassembled , stick is not going back forward like a spring is broke , All good from veiwing when apart. now have a click when pulling back on stick .. Looks like around the area of the the brake linkage . Could the problem lie in the throw out bearing assembly ? Left side is perfect good pull and allows stick to go back foward . Case is coming back off . Getting really good at pulling case off .. Any input, I thank all in advance . Good day .
Are the springs for the cam attached and in good shape?
They help to return the cam to the neutral position.
Dan.
- Site Admin
Post
by Lavoy » Mon Jul 09, 2012 8:38 am
Most likley the adjustable link between the steering shaft and the throwout bearing is too long, and needs to be shortened, just did this to both sides of a 440 I had in the shop.
If you hear a click when you pull back on the steering levers, the brake band is grossly out of adjustment.
454BBGB
Post
by 454BBGB » Tue Sep 04, 2012 7:11 am
Looking to get the springs for the cam on the right side drive . Have been to all the local CoOp and auto stores no luck .. Do I need to go to the Deere counter ? Thanks
2 Lungs
- Site Admin
Post
by Lavoy » Tue Sep 04, 2012 10:13 am
I stock all the final drive and steering clutch parts.
Owner and moderator
www.jdcrawlers.com
454BBGB
Post
by 454BBGB » Mon Sep 10, 2012 5:47 pm
Lavoy ,
Would like to place an order . PM me the contact info. Thanks
2 Lungs
Paulywally
Post
by Paulywally » Mon Sep 10, 2012 7:50 pm
454BBGB wrote:Lavoy ,
So what ended up being your final problem. You should post some pictures.
1057 5 roller 420c with Henry loader and too big of a bucket.
454BBGB
Post
by 454BBGB » Sun Sep 30, 2012 7:16 am
Got all back together , issue now . Bearing quill cover when is installed all tightens up . The handle pulls hard and as before dosent opperate smoothly. Any tricks ? When the cover is not on the case, everything moves as it should . Install the cover ,all tightens up. Thanks in advance for the tips .
2 Lungs
454BBGB
Post
2 Lungs
whiteclipse16
Post
by whiteclipse16 » Sun Sep 30, 2012 8:56 am
Sounds like you need to add some shims to the quill cover.
Ben
454BBGB
Post
by 454BBGB » Mon Oct 01, 2012 5:07 pm
Is there a trick to find the amount of shims needed ? Thanks for the help.
2 Lungs
Users browsing this forum: Bing [Bot] and 8 guests
