Looking for hydraulic pump
John K 1959
Post by John K 1959 » Mon May 28, 2012 4:21 pm
I am looking for a hydraulic pump for an 831 loader on a 1960 440 IC. It is a Cessna pump. I have tried to find parts to rebuild mine and have been unable to locate all the gaskets. If anyone has any leads on a good used pump I would greatly appreciate the help!
John K
440IC Ser #458500
whiteclipse16
Post by whiteclipse16 » Tue May 29, 2012 11:40 am
I thought the loader machines were suppose to have the larger hydreco pump.
You might try this place for a replacement pump
http://www.surpluscenter.com/sort.asp?c ... rch=cessna
This place might have the seals if you haven't tried them.
http://knighthawksupply.com/cessnapumpid.htm
Ben
John K 1959
pump
Post by John K 1959 » Tue May 29, 2012 4:16 pm
Ben there were 3 pumps used on the 831 loaders the Hydreco that you referred to and then 2 Cessna pumps the15535-1TA up to 1961 and the 20014-1FFA from 1961 on. They do not list what years the Hydreco pumps were used. I have the earlier Cessna pump on mine. Thank you for the surplus center info they look quite handy to know about. The KnightHawk place I did already try and they had nothing. I have a cpl of feelers out on repair parts so maybe something will turn up. If not then I will just have to use a new pump and fabricate a coupling and mounting brackets. Thank you again for your help!!
John
440IC Ser #458500
Users browsing this forum: No registered users and 179 guests
