450b fuel tank vent
Brockway761
450b fuel tank vent
Post by Brockway761 » Tue May 08, 2012 8:15 am
Hello again, On our 450b I don't see any vent in the fuel cap, and each time that you remove the cap there is a strong vacuum. Is there a vent somewhere that could be plugged???
tjdub
Post by tjdub » Tue May 08, 2012 2:07 pm
When you take the cap off, you'll see a small diameter tube behind the dipstick tube. That tube goes out through the bottom of the tank. Probably plugged up with a mud dobber or some other bug. Just run a piece of wire down it to clean it out.
Brockway761
Post by Brockway761 » Wed May 09, 2012 6:26 pm
Thanks, I'll give it a try!
