jdemaris
Post
by jdemaris » Mon Apr 16, 2012 6:08 am
pwright0001 wrote:when lower tube is pressurized i hearair inside and front shaft doesnt feel like it is engaged.
If putting air into that tube does not lock up the clutch tight- you've got internal problems. The "air test" is something you always should do before installing.
pwright0001
Post
by pwright0001 » Mon Apr 16, 2012 11:22 am
Even with an internal leak should fluid still not be flowing to cooling lines and electric sending unit ?
Its not a sin to be poor, Just inconvenient !
pwright0001
Post
by pwright0001 » Tue Apr 17, 2012 9:00 pm
any thoughts about no fluid flow ? anybody ?
- Site Admin
Post
by Lavoy » Wed Apr 18, 2012 7:50 am
I would assume it has to be pump related, either the pump is not working, or something is preventing it from getting oil, or it is not priming for lack of a better term.
pwright0001
Post
by pwright0001 » Wed Apr 18, 2012 10:37 am
ok, thanks . Would it be a good idea to have a machine shop resurface the face of the gears along with sealing edge of the pum,p body and cover ?
- Site Admin
Post
by Lavoy » Wed Apr 18, 2012 1:39 pm
I would check the clearance with Plastigauge first.
pwright0001
Post
by pwright0001 » Wed Apr 18, 2012 2:19 pm
do you know what the clearance should be ?
- Site Admin
Post
by Lavoy » Wed Apr 18, 2012 3:44 pm
A few thousandths I would guess.
