Gus
Gus for future reference, you can clean a tank out with a cleaner such as Simple Green, Castrol Super Clean or Marine Clean from Resto-motive Industries, then wash it out with HOT water and drain it. Then blow air through it to dry it out, place a final purge of CO2 in it before you start welding if you are still nervous about it. To make cleaning the welding detritus easier spray some anti-splatter into the tank before you put the final purge in the tank.gus wrote:THINK MAN THINK........gus wrote:The tank is welded and painted. I welded in a drain, the new mounting tabs and also added a large tab on the outside to help carry the extra weight. I have increased the capacity to over 5 gallons from the original 2.5. I'm not quite sure what it was but I think in that range.
After all this I realized the the new pump had more capacity and needed bigger lines!!![]()
Now I have to go back and cut out the holes and weld in bigger fittings.And, the tank was rinsed with a volital fuel to get the welding crud out.
Now it needs to be steamed or defumed to cut and weld on it.
I'm also looking into putting a filter on the return line. I think the system will have a longer life if I do.
Gus
I'm not sure I even know how to post on YouTube, never have.Paul Buhler wrote:When can we see some video of your machine running on YouTube? Paul
Or take the video and have a 13 year old do the upload for you - annoying but efficientPretty easy. Download your video(s) to your computer, upload to YouTube. Then, copy the link on YouTube and paste it in a message on here.
Users browsing this forum: No registered users and 181 guests
