Looking for used CAT D4 track pads
sbjuke
Post by sbjuke » Tue Feb 28, 2012 2:10 pm
I am looking for anyone who has info on some used track pads for a Cat d4...I have an OC12 and the chain/rails for a cat D4 are the same ...i already have enough chain/rail too make 2 sets for this crawler....just need the pads.......please let me know if you know of anyone......thanks
JUKE
Post by Lavoy » Tue Feb 28, 2012 4:32 pm
I can't find my tooling charts right now, but I question if they are the same rails. If they are, that would be the first example I have heard of commonality between manufacturers in undercarriage, especially that far back. You might have more nowadays, but back then, everybody's rails were different from everybody elses among the major manufacturers.
sbjuke
They are a perfect match other than pads
Post by sbjuke » Tue Feb 28, 2012 8:19 pm
We have actually taken the tracks off of the oc12 and placed the rails from the D4 on it and everything matches up with the sprocket teeth ,rollers and front wheels .......the spacing is perfect from side to side...they actually fit better than the originals.......if we could just swap the pads we would .........but unfortunatley it would be way to much work ... the front 2 holes line up perfect but we would need to burn the back holes out along with the bottom lip on each pad........this is why we are looking for D4 pads......thanks
JUKE
sbjuke
Post by sbjuke » Tue Feb 28, 2012 8:30 pm
I also have A JD 440icd with an 831 loader that is in excellent condition other than the hydraulic valve.....i am thinking over the idea of replacing it with a joystick......this crawler is at my camp and i can't get to it till spring ....you wouldn't happen to know the thread size on the valve would you?......That way i can order one now and then replace it when i go there...saves me a 100 mile trip........oh and i am also looking for the threaded track adjuster for this machine....just need the threaded end not the hole piece.......threads are mushed pretty bad.......thanks
JUKE
Post by Lavoy » Wed Feb 29, 2012 9:06 am
Make sure you get a joystick that will go down to 1500PSI or you will damage something.
Not sure on thread size, sorry.
sbjuke
Post by sbjuke » Wed Feb 29, 2012 9:17 am
thanks.......yes the prince joystick i'm looking at has an adjustable relief from 1000 psi to 2500 psi..............thanks.........if anyone out ther knows what the fitting thread size is on the original 2 lever valve for a 831 loader please let me know........thanks in advance............JUKE
JUKE
Users browsing this forum: No registered users and 181 guests
