front idler repair 350 straight
Hello !
I called two different shop for having my front idler repaired
( recharge welding ) because they are 1/8 two thin and they might
start touching the bushing in a near future , the answer was :
We cannot weld these idler because of the type of casting that is been used it will cause them to break in two pieces , they can't bear any heat .
gee I'm then back to square one , I keep them like they ,are try to find used one ( which I did without any success ) and or buy new ones wich seem to be
not a easy task and pretty expensive .
any tricks or ideas are more than welcome
for now I will spleep on it .
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Those kind of repairs used to be common back in the day. In todays world it is cheaper to replace with new (China or Korean made).
I have a mid 70's 450B which will need the same repairs as your dozer.
So have searched the Web and found Navy Welding Materials Handbook (P-433). This handbook has alot of information on dozer undercarriage repairs.
Lincoln Electric also has a handbook, also very helpful. I am still researching this and hope to start later this year. I have had the 450 about 1.5 yrs and have been slowly buying parts.
Like someone has said "I have more time than money". My dozer is for Farm/Ranch clean up. It will not be used everyday to make a living.
Hope this helps.
Hope this helps.
Re: front idler repair 350 straight
These threads may be helpful to you, especially the first one:andregrondin wrote: I called two different shop for having my front idler repaired ( recharge welding ) because they are 1/8 two thin and they might start touching the bushing in a near future , the answer was :
http://www.jdcrawlers.com/messageboard/ ... oller+wire
What they told you is true for many newer undercarriage parts because of the new alloys being use. It is NOT true of OEM 350 idlers. I've seen many get built up just fine - with a flow-weld machine or by hand.andregrondin wrote:Hello !
- push&pull7
I look at it this way. What do you have to loose. The idlers are made of Malleable Cast Steel. Not Cast Iron. Use a good Malleable rod like MR7018 and go for it. The worst that can happen is it will break out again.
Users browsing this forum: No registered users and 244 guests
