winch
DukeofDeere
winch
Post by DukeofDeere » Sun Nov 27, 2011 12:01 pm
Are there any manuals etc. available for the winch on my JD 440IC ?[/u]
Post by Lavoy » Sun Nov 27, 2011 4:47 pm
Depends on the brand, Gearmatic is easiest.
DukeofDeere
Post by DukeofDeere » Sun Nov 27, 2011 8:28 pm
Ok
I will check which model it is soon.
I recall it saying Winch drum on it.
Model 8.
Will verify tomorrow.
Post by Paul Buhler » Mon Nov 28, 2011 10:13 am
If you have a Gearmatic 8a or g, I can send you a .pdf copy of the manual if you email me. Paul
DukeofDeere
Post by DukeofDeere » Sat Jan 14, 2012 12:58 pm
Thanks for the pdf file.
What size cable belongs on this 8a winch drum and how many feet will fit?
Thanks,
Duke
fruitcakesa
Post by fruitcakesa » Sat Jan 14, 2012 4:49 pm
I got 120 ft of 9/16 cable on mine
196? 1010 diesel crawler, Gearmatic 10 winch w/ arch/fairlead, 6 way power angle blade, ROPS w/rear screen
Post by Lavoy » Sat Jan 14, 2012 5:52 pm
Don't hold me to it, but from what I remember:
3/8"-365ft
1/2"-185ft
5/8"-120ft
DukeofDeere
Post by DukeofDeere » Sat Jan 14, 2012 7:55 pm
I just found 125 ft of 9/16 galvanized cable.
Thanks for the info!
Duke
DukeofDeere
Post by DukeofDeere » Tue Mar 13, 2012 2:08 pm
Are there rebuild kits available for the winch actuator?
This one is a single leaver with one line coming out of it.
Thanks,
Duke
Post by Paul Buhler » Tue Mar 13, 2012 3:59 pm
What kind of winch do you have? Do you know the kind actuator you have? If Lavoy doesn't have what you need there is a place in NH that has many Gearmatic winch parts. Check with Lavoy first since he hosts this place. Paul
Post by Lavoy » Tue Mar 13, 2012 4:11 pm
Not sure which one that would be, the 8A Gearmatic has two lines coming out of the controller.
DukeofDeere
Post by DukeofDeere » Tue Mar 13, 2012 5:22 pm
The winch is an 8A.
I will get a picture of it soon.
Thanks,
Duke
Post by Lavoy » Tue Mar 13, 2012 6:19 pm
8A would have two lines, one for clutch, and one for brake.
DukeofDeere
Post by DukeofDeere » Thu Mar 15, 2012 5:55 pm
I am looking for an actuator for my gearmatic 8 a winchdrum.
Let me know what you have.
Thanks,
Duke
