cbc injection pump
cbc injection pump
does the fuel shut off solenoid act as a relay to transfer power to the pump to allow fuel to pass.
1969 jd350 crawler dozer
My understanding is that it doesn't transfer power, but rather is an electrically-activated plunger that when powered allows fuel to pass by moving the plunger away from the fuel passage, and shuts when power is turned off to the plunger. Some people remove the plunger assembly when the solenoid goes bad to allow the pump to still operate.
Jdemaris describes this in his posts about 1/2 way down on page 1:
http://www.jdcrawlers.com/messageboard/ ... t=solenoid
yes i read jdemaries's post on the subject. from the pics that i've found the pump has a stem pertruding out the side with a wire attached to it , is that part of the solenoid . from the pics on the jd website their are four coponates , nut , sleeve , spring, and a washer . i dont see a coil for a solenoid to work.
I'm not sure what photos you refer to, and unfortnately can't take a photo as I don't have a CB pump.
However the solenoid is a solid cylindrical object with a plunger on the interior end; the outer end has two slots for the special removal tool.
There is a illustration of it on page 16-15-2 of SM-2046 (the service manual for Roosamaster fuel injection pumps).
He was just on here last week, but I don't notice him posting on a frequent basis. He does also visit the YT site, last I looked. Try sending him a PM.
jdemaris
Re: cbc injection pump
What we often call an "injection pump" is actually two pumps inside the same container. One is the high pressure pump that makes injection. The other is the low pressure pump that does three things - feed the high pressure pump, run the automatic timing advance, and draw fuel from the tank (not needed on engines with separate lift pumps).lp14255 wrote:does the fuel shut off solenoid act as a relay to transfer power to the pump to allow fuel to pass.
When you cut power to the fuel shut-off solenoid - it blocks all flow from the low pressure pump so it can't get to the high pressure pump. C pump uses a spring loaded plunger and the D pump uses a metal spring-loaded arm the pushes the metering valve closed.
Users browsing this forum: No registered users and 118 guests
