a 1010 deader than a door nail
Hello, I just rebuilt the generator and then installed a new regulator on my 1010 diesel w/ 6 way blade. It ran well a week ago and yesterday I went to start the old girl and it had absolutely nothing.... no click, no anything. The battery is charged but it is a no go. Have any of you guys any suggestions on what the culperate might be?????????????? It seems that the 10 / 12 years I've had this machine it n e v e r ceases to fail me with something going wrong almost evert time I use it. A true drain on my fiscal responsibility Thank you...
Dirty or loose battery cables (either end) will do it every time. It will even effect the rate the generator charges the battery when running too.
How did you check the battery? Cranking amps is what is needed, not just voltage. You can also check the voltage drop across the battery terminals when cranking. If it goes to near zero, then the battery is bad.
JD 2010 Crawler with Loader
I tend to agree with Mark- if everything else was working a week ago I would first suspect the battery. I have had batteries that seem to be fully charged but have a bad plate and are essentially dead. I bought a load tester that really helps. the batteries will show a full charge with no load and then when load applies show on the load tester as being shot.
A loose or corroded ground terminal to battery will also have the same symptoms.
- Paul Buhler
Another heads up: Make sure that your battery cables are in good shape and properly sized. Corrosion inside the cables or too small a cable will cause problems too.
When I bought dozer batteries in the past, I bought ones designed and sized for my particular dozer - they are more shock resistant and you have less internal problems from plate separation and internal shorting. Good luck finding your particular gremlins. Paul
dead as door nail
Hey Randy -- Same thing happened to me. It was corroded post inside the solenoid. Take a look. Greg
As others have said, check the cables as one of the first things. When I got my 40c it came with a brand new battery but it would turn over. Very well to do guy owned it and his estate manager gave up trying to figure out why it would not turn over. I got it for the as-is price
. Took me and a family friend about an 1/2 hour to narrow it down to a bad ground strap, which looked fine.
- 440 iron popper
A good multimeter on the battery and a clamp-on ampmeter will tell you what's going on. Test When it's running and the draw of current when stopped.
Users browsing this forum: No registered users and 179 guests
