Question for a 40C
JD Tat guy
Question for a 40C
Post by JD Tat guy » Sun Aug 28, 2011 7:54 pm
I was wondering for the blade on the front, did it only have one cylinder to control up and down? Is it in a float potion? I use it for grading the driveway but its not level. Thanks again.
Willyr
Post by Willyr » Mon Aug 29, 2011 2:37 pm
Depending on which blade you have, yeah they never got it perfect. There was an uneven grade, even after you tighten up all the joints.
former owner of a 1956 420c
JD Tat guy
Question for a 40C
Post by JD Tat guy » Mon Aug 29, 2011 7:37 pm
I can try to tighten up all the joints and see if that works better....I just thought if there was a cyclinder on each side that would help out.
Willyr
Post by Willyr » Tue Aug 30, 2011 5:11 am
The second cylinder will hamper your ability to remove the battery. My tractor has a second and I must remove the hydraulic cylinder to get the battery out.
Post by Lavoy » Tue Aug 30, 2011 9:48 am
The second cylinder will make no difference, any slop you have is in the linkage and pivots.
JD Tat guy
Question for a 40C
Post by JD Tat guy » Tue Aug 30, 2011 7:06 pm
Thank you for the help!!
boler76
40c hydraulic
Post by boler76 » Wed Aug 31, 2011 5:13 pm
my 40c has a float option, it is explained how to enable it in the manual. at least in my manual. There is a hex cap on side of control valve and if I remember rightly you take it off and tske the plunger out and reverse it for float?? Going from memory not manual. Try it.
Users browsing this forum: original possum and 29 guests
