Question for a 40C
Question for a 40C
I was wondering for the blade on the front, did it only have one cylinder to control up and down? Is it in a float potion? I use it for grading the driveway but its not level. Thanks again.
- Willyr
Depending on which blade you have, yeah they never got it perfect. There was an uneven grade, even after you tighten up all the joints.
former owner of a 1956 420c
Question for a 40C
I can try to tighten up all the joints and see if that works better....I just thought if there was a cyclinder on each side that would help out.
- Willyr
The second cylinder will hamper your ability to remove the battery. My tractor has a second and I must remove the hydraulic cylinder to get the battery out.
Question for a 40C
Thank you for the help!!
40c hydraulic
my 40c has a float option, it is explained how to enable it in the manual. at least in my manual. There is a hex cap on side of control valve and if I remember rightly you take it off and tske the plunger out and reverse it for float?? Going from memory not manual. Try it.
