JD 1010 ICD Glow Plugs
Just bought a 1010 ICD with 810 loader. Gentleman I bought it from has always started it with a shot of starting fluid (which kind of scares me, as I know what harm can be done by such chronic practises). I have not had much time to dive in and investigate yet, but how big a job is it to install glow plugs? As I said, I have not even checked out to see if there were any on it originally, but I have a source for new ones. Also preparing to drop all fluids and change out all filters, just to be safe. Any other thoughts on inspecting? Undercarriage looks very good, pins and rollers look good, but I do need to slightly tension the tracks. Thanks!
40U Orange (CJ 108)
320U Yellow
420T Yellow
420U Yellow
420W Orange
420W Yellow
430U Yellow (CJ 265)
730D STD ES
1010 ICD w/810 Loader & 50 Backhoe
3010 Industrial Wheel w/720 Loader (Gas)
3010 Industrial Wheel w/Ldr. (Gas)
320U Yellow
420T Yellow
420U Yellow
420W Orange
420W Yellow
730D STD ES
i belive all had preheaters they are about as easy as changing spark plugs if you still have the org. switch you turn it to the left for preheat then to the right to start and as the starter is engaged it also powers the preheaters
ALL 1010's had glow plugs, and ALL 1010's require preheating prior to starting, regardless of outside temp. Glow plugs only heat when the switch is turned to the left, use 30 seconds for warm days, up to a minute and more on really cold days.
I stock both styles of glow plugs, they are easy to put in assiming the tip does not break off in the pre-cup.
nos switch
i did mistype and said right when i ment left and i double checked and if you have a nos key switch you will find that it powers the preheaters while in the start mode i have taken two of mine apart and cleand and lubed them and that is the way they are ment to work not trying to be an ass just i know thats how they work
Users browsing this forum: Jim B and 146 guests
