deleted
Ken
The press idea is the most ideal way to go if you can fit it in and move the pan around easy enough. You could also try using your backhoe attachment to press on the pan, usually you can get more weight on a concentrated area with the teeth. If that still wont budge it you could need to heat it then push on it.
i know what a skid plate is the 350 plate dont look any thicker to me in that pic than a 2010 plate. i have done mine a 2010 every time i took it off 3 or 4 times in the last 42 years two blocks of wood 2x4 on each side of the bend and swing you cant use a tack hammer
- 440 iron popper
I pushed start it, and then I shifted to fith gear... You can't see the fear through his full face helmet he had when he saw the awsome power of the 440.. What a pursuit!Lavoy wrote:Okay, one of two things. Either that must be the hardest starting 4 wheeler in the world if you need a crawler to push start it, or it is the best 4 wheeler in the world if it will pull start a crawler!![]()
- JD440ICD2006
I believe that the 440C's are the best power for the size and weight, unless you have big stumps and stuff to move.
Hard to believe that two cylinders and the way they have it geared will move as much as it will.
- 440 iron popper
You're right 2006. I'm the only one around here who also believe that!! Surprising power, vintage engine sound.
When I'm done with my rebuilt, the crawler will surprise people around of what a 2 cyl engine can achieve.
When the crawler was half dismantled (engine, clutch, reverser removed), I turn the input shaft of the transmission by hand in first gear just for fun. It went forward on its rollers...! I guess I could hook a 18Volts drill on the shaft and have it run good. Have a well aligned frame, good rollers and you get a war horse. So the 30 hp engine is a real power plant in front of that.
The sound and the amount of power is from the fact that it is a two stroke so in therory its a 4 cyl at least for power. Truckers called jimmys yamahas i have a 10 wheel 18 yrd dump truck with a 6v53 in it top rpm is 2800 a friend says it sounds like a b52 when its coming towards him
- JD440ICD2006
Actually, his is a 4 stroke. (440IC) It is the same basic vertical 2 cylinder gasoline engine that JD put in Dubuque tractors for years.
They also offered the GM 2-53 diesel (440ICD) as Dubuque did not build a 2 cylinder diesel.
The 2 stroke diesels sound like they are running so fast because the power pulse sounds are doubled. It "fires" every stroke.
The roots type blower adds to the sound also.
Hi !
Ken did you remove the tranny form the loader when you fixed it ?
also to straightened the under protector use a backhoe bucket that you curl going forward and backward and it worked for mine !
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
