Power Steering Leak?
GlennP
Post by GlennP » Thu Jul 14, 2011 11:55 am
Any suggestions on how to locate the problem with the power steering reservoir leaking? Shortly after filling the reservoir it completely drains everytime. No idea where it is going and alos wondering if is okay to operate with no fluid? Thanks!
Glenn,,,
1970 350B Crawler Loader
KenP
Post by KenP » Thu Jul 14, 2011 2:28 pm
deleted
gerald
Post by gerald » Thu Jul 14, 2011 6:19 pm
Kemp What do ya think the differnce will be if the power steering was working? My power steering has been empty for years. I'm afraid the pump will lock up and set a grenade of in the engine.
KenP
Post by KenP » Thu Jul 14, 2011 7:15 pm
deleted
GlennP
Post by GlennP » Thu Jul 14, 2011 8:26 pm
Ken,
I will check the engine oil level next time I fill the reservoir. How will this impact the engine?
Glenn,,,
KenP
Post by KenP » Fri Jul 15, 2011 4:33 am
deleted
jtilsond
Post by jtilsond » Sun Jul 17, 2011 8:51 pm
There is another fix.
We teed off a line from the engine oil pressure sending unit to the top of the power steering cannister. Put a cutoff valve in the line to control the trickle of oil into the reservoir. Use motor oil to power the power steering and as it trickles back into the engine it just recirculates. Less than 20 bucks to solve the problem. I will overhaul the pump someday when I have more time. Its been about 3 years with this method though!
Oh, I did use some silicone or form a gasket to seal the reservoir in case you allow too much oil to trickle in sometime. It is controlable!
