john deere 550a reverse problem
dblaz
Post by dblaz » Sat Jun 18, 2011 2:52 pm
Hi I have a 550a that goes forward fine but when you go in reverse it starts out fine then goes really slow it has a new pump already installed any help would but greatly appreciated
Thank you
Dave
Jd 1010 diesel 53 cat d69u 57 cat 955 loader. 78 951c
Post by mini kahuna » Sat Jun 18, 2011 4:44 pm
you have something causing a oil pressure drop or clutch problem in the reverse system of trans.
lots of times it is the piston and or piston seal leaking pressure and this causes the clutch to not be applyed with full force and you start slipping.
you don't want to slip that trans,it will just heat up the clutch pack and warp the clutch plates "it has most likely already happened".
dblaz
Post by dblaz » Mon Jun 20, 2011 7:09 am
So is it servicable in the dozer or do you have to drop trans completly out of it also I have heard of some lines cracking inside the trans creating a problem like this anyone else hear that
Dave
Post by digitup2 » Mon Jun 20, 2011 2:05 pm
check your lines but bet on the piston seal for reverser.I have had many apart but never had a Deere with cracked lines .That is more an Allis or Cat thing but check it out when in there.It will probably be the reverse side piston seal is gone.and that is inside the rear end .PS some say you got too take the motor out and others like me have left it in for the job! .Digitup.
dblaz
Post by dblaz » Mon Jun 20, 2011 2:14 pm
Have you worked ot a 550 before I assume I seen on another post I believe it was u that had said you can acsess from the top that sure would be easier that taking engine out
Post by mini kahuna » Mon Jun 20, 2011 7:19 pm
digitup is very familiar with the guts of the 550,I am betting on a piston seal blow out too.
if you are comfortable working on heavy equipment,it's not to bad of a job,but you need to know what your looking at once you get in there.
Users browsing this forum: No registered users and 231 guests
