450C Pivot Pin Bushing
Farmboy
Post by Farmboy » Thu May 19, 2011 9:51 pm
Made from schedule 40 2.5" pipe
450C
vestor_guy
bushing
Post by vestor_guy » Fri May 20, 2011 7:37 am
That is an interesting bit of machine work. Can you describe the process?
Farmboy
Post by Farmboy » Fri May 20, 2011 7:53 am
I had a huge amount of blade slop.
You can see how the top of the pivot pin was badly worn.
Interestingly, the hole in the back of the blade wasn't worn nearly as much.
(Must be harder metal)
We noticed that the hole was about 2.7" and the pin was about 2.5".
2.5" Schedule 40 steel pipe has an ID of about 2.5 and an OD of about 2.75".
Just turned the pipe down to 2.7" x 2.25" (The pin length is 2.00" but there is room for extra length in the hole in the blade).
Still have to put some weld bead on the top side of the worn pin and then grind back before putting the busing over the pin.
Also going to drill a couple holes in the bushing so we can do a slug weld and will also weld around the inside of the bushing at the end of the pin.
Should give a nice fit that I hope will last a while.
Bill
450C
vestor_guy
Bushing
Post by vestor_guy » Fri May 20, 2011 8:22 am
When you see that much wear on the pivot pin, there will also be a lot of wear on the back of the blade where the pivot arm slides up and down. On the first 450 I owned, I built up the worn areas on the back of the blade and ground them flat again. It helped take most of the slop out of the blade.
Farmboy
Post by Farmboy » Fri May 20, 2011 9:44 am
Vestor,
I'm not sure I understand where you mean.
Could you elaborate please?
Thanks!
450C
vestor_guy
Pivot pin
Post by vestor_guy » Sun May 22, 2011 6:26 am
The function of the pin you are bushing is to just provide a point of rotation for the blade. It cannot be used to take "slop" out of the bade system without overstressing the pin.
To remove the "slop" in the blade you need to rework the clearance between the ends of the pivot assembly and the blade. Originally, there were shims you could remove but you are probably well past that point and the shims have been removed.
If you remove the two "partial arc" pieces from the blade (you have obviously already removed them) you can see the differences in wear on the back of the blade from the upper arc to the lower arc. I just built the worn area back up with a soft fill rod and ground it back level and smooth. That will take the "slop" out of the blade without bushing the pin.
Farmboy
Post by Farmboy » Sun May 22, 2011 9:02 am
Yup... understand.
Thanks.
450C
Farmboy
Few More Pictures
Post by Farmboy » Sun Jun 12, 2011 7:50 am
450C
Post by digitup2 » Sun Jun 12, 2011 1:11 pm
That looks like a good job .You may have to shim the blade plates though .Digitup.
vestor_guy
blade pivot
Post by vestor_guy » Mon Jun 13, 2011 10:21 am
The blade plates will also have wear. If you build those up flat, you will need the shims. If it is too small a clearance, the cylinder will not be able to tilt the blade while digging.
Users browsing this forum: No registered users and 108 guests
