blocking locations to support a 420
- Paul Buhler
Hi: I'm looking to block up my 420 so I can remove the tracks for re-pinning and bushing. I was wondering if the pans on the final drives are a good blocking location? If so, it would allow me to have the machine lower to the ground on a sturdier, nom. 8x8x16 and 2x stacked set of wood blocks at the rear with additional blocks under the blade and then front cross bar. If I need to use the rear cross bar the stack looks to get higher and more wobbly.
Thanks for any thoughts.
I'll fill you in on my track job when it's done - I'm taking pictures as I go. Paul
420 support
Paul,
Blocks under the final pans are just fine.Where those things are
located they take plenty of abuse.One thing you might try is to
jack up one side and remove the track.Slide a 4x6 under the rollers
and let the thing down.Secure the machine from rolling and repeat
on the other side.I have done this before and it works well.Two
2x6 stacked will work if you can't get 4x6s.Where did you find pins
and bushings?Hopefully not from the latest batch from Korea.
Luck,JimAnderson
Luck,JimAnderson
6x6 blocks under each side of the drawbar support, and the front held up by the blade and blocked as shown.
Did not even need a jack, just raise the front, slip a 2x4 under the center rollers, raise blade to tip machine forward, blocks under the back, then raise the whole machine off the ground with the blade.
- Willyr
My prior 420 I did the similar thing. Yet I backed the crawler out of the shop. Popped the pins (I had jacked the tracks up prior and got the pins in same spot), then drove the tractor back into the shop allowing me to get off of 75% of the track.
Then I went with a floor jack and raised backend to accept the 8x8 blocks and some 2x4. Then push down with blade and your free.
former owner of a 1956 420c
- Paul Buhler
Hi:
Thanks for sharing your thoughts and experiences. I'm planning to block up the tractor on a level parking area so that I can split the tracks, lay them out and winch them onto the tilt bed car carrier that I have available; I'll roll them up once loaded.
While off, I want to take off the frames and replace two bad rolls. I might even put on some new paint.
When I get them back, I'll unload them at the back of the crawler with the idea to lever them under the sprockets and last roll, lower the crawler a bit, (2 x whatever, under the other rolls) and back onto them, and then come-along them together (The short version of the real exercise which involves leverage, lifting, grunts and groans) to put in the master pins. If that doesn't seem to work, I'll go to plan B. The last time I put tracks back on I had an excavator to help which made the lifting and dragging part easy. No such lifting help this time.
I'm always open to other ideas as well.
Paul
Paul
- Paul Buhler
I like it; quick, easy and safe.I lay down a 4x4 wood drive on it until dozer rocks forward, then I put a block that is precut under the drawbaw(fits tight), then I activate the blade down and the dozer raises it self, then I put jackstands under square pieses that tracks are hooked to. Then you're ready to have fun.
When I had a 450c with a winch, we did it the same way with the block under the winch, but the winch on the 420 is attached differently and I didn't want to cause a problem while trying to solve another.
Thanks. Paul
- Paul Buhler
Tracks are off. Thanks for the help - I used bits of everyone's thinking.
Used 4x4 blocks under the tracks to lift the rear. Blocked under the finals then lifted the dozer with the blade on 12" high blocks, which freed the 4x4s and allowed jack stands to be placed under the front cross bar. Lowered the machine onto the jack stands - nice and solid. Spun tracks, loosened tension and removed master pins at the idler end. Found that I could "back off" the tracks one side at a time - they flopped off to the rear without incident - easy and sure saved a lot of lifting. They'll be off to the pressman this week I hope. Now I can play with the frames, bad roll(s), and replace one front idler.
Jim: The pressman has a supplier. He's used these pins and bushings before with good results; I don't know at this time where they come from. If I like the results, and the pressman is willing, I'll share his name and number here.
Note the snake? Haven't thrown a track yet, but I knew it would only be a matter of time with that much slop working on the side hills around here.
EDIT: 7/16/14
I tried to organize my Photobucket albums and wound up corrupting the following pages' links, so I've posted a new link to my 420 album. You'll have to sort through to match pictures with descriptions. Sorry, but it would take me longer than I want to re-establish good specific links. Hope you find the pictures helpful. Paul
http://s460.photobucket.com/user/pbuhle ... t=3&page=1
EDIT: 7/16/14
- Paul Buhler
I have an extra front Idler assembly already. I got it, and two rolls from Fred in Chester VT. He advertises on VT craigslist. He's currently parting out a 430.
http://burlington.craigslist.org/grd/2353553131.html
Now don't be buying all the good stuff.
Paul
Paul
430 parts
I have been dealing with Fred for years.He is very reasonable on his prices and has a neat collection of tractors.I was at his place 2 years
ago and unless you have a big trailer you won't clear out his parts
collection.Luck JimAnderson
- Paul Buhler
420 support
Paul,
The first thing i thought of when Fred's name came up
was the same thing you just expressed.A very good secret revealed.
With that said, over the years I have come to realize that this
is a very small community and sooner or later everyone gets
to know everyone.I had been dealing with Fred for sometime and
got to the point where we would call each other to say hello.During
one such conversation the subject of small gas engines came up.I
told him that my father in Maine ,who just passed away, had a
considerable collection of them.Fred realized that the person who he visited several times was my dad and he knew his collection well.
I finally got a chance to meet Fred face to face and he is an
amazing person and quite a gentleman.Luck,JimAnderson
- Paul Buhler
Jim: I called Fred last year and scheduled an appointment to see what he had for parts. As you said, he's very personable and took the time to show me his many "toys". I liked the way he organized his space - neatly. I felt like a kid in a candy shop and thought of all the "nice to haves" I could have bought that day. He let me pick through and choose the parts I wanted, and his prices were fair. As you know he spends part of each year in Chester, Vt and part down in Florida running a different business.
I hope our combined demand doesn't force him to raise his prices. Paul
Users browsing this forum: Google Adsense [Bot] and 223 guests
