12 volt conversion on 420c
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Tue Mar 15, 2011 4:28 pm
I like the idea of having a key for my 440 because some times i need to leave it on a job.my show crawlers i leave the negative cable loose and remove it from the battery at the shows just in case? :)
nothing crawles like a deere
snickers
Post by snickers » Wed Mar 30, 2011 7:04 pm
Thanks guys!!!
i have decided to go the 12 volt route, and have my starter and generator being rewound for 12v instead of 6v. getting everything done for $105.00 at a local rebuild shop, i dont think that sounds to bad? and that price also includes a new regulator and coil!!!
i am also going to install a key type starter switch and a solenoid switch just for safety!! all i need now is new steering clutches and a little bit more fresh paint and i will have the old girl back in the woods!!!
1957 420c
Post by Paul Buhler » Thu Mar 31, 2011 5:14 pm
Hi: I'm curious, why would a person want/need to convert to a 12v system? Are there any particular advantages? Thanks. Paul
Willyr
Post by Willyr » Thu Mar 31, 2011 9:19 pm
12 volt the engine will wind over faster, more products available for 12 volt, smaller batteries, less current required to start, wires dont need to be as heavy. These are some of the popular reasons. The alternator tends to be a little more robust than the generator. But its really a matter of prefference.
My tractor was 12 volt, yet a properly set up tractor on 6 volt, all the abve reasons are moot point.
former owner of a 1956 420c
Post by Paul Buhler » Fri Apr 01, 2011 9:21 am
Thanks the info you shared is helpful. So far mine's working well as designed (6v), so I'm not looking to convert. Paul
Post by Lavoy » Fri Apr 01, 2011 10:09 am
By and large a 12 volt conversion is only to hide an existing charging or starting system problem that if fixed correctly would work just fine on 6 volts.
Converting the starter and generator to 12 volts is the best way to do it by far. It eliminates the starter drive, housing and ring gear damage issues associated with 12 volts on a 6 volt system.
snickers
Post by snickers » Mon Apr 04, 2011 3:32 pm
Paul, my primary reason for making the switch is lighting, my original gen needed to be rebuilt and it just made sense to make the switch now. i plan on running lots of lights for night work around my cabin, and the sheer cost and availability of the lights made me make the switch. i am keeping the original looks by using the 6v housing and now if i need to jump start the ole girl i can use my truck.
1957 420c
