12 volt conversion on 420c
need some advice, i am currently rebuilding my 420c and want to do a 12 volt conversion on it but need some advice on how to do it. first is should it be set up as a positive ground? or conventional negative ground? i also am not sure if i need to change the points and condenser in the distributor? will the original amp gauge work on a 12 volt system? when i bought the crawler it had a 12 volt starter in it but no charging system hooked up. the only wiring that was in the tractor was a hot wire going to the coil and a button switch to the solenoid so i am going to rewire everything.
Any help is appreciated!!!
1957 420c
There have been a lot of great posts in the past on this subject- these threads should help you:
http://www.jdcrawlers.com/messageboard/ ... t=positive
- JD440ICD2006
Negative or postive polarity on these is a matter of choice. The only thing that needs to be done is to polarize the generator BEFORE turning the switch. This is true on either 6 or 12 volt anytime you disconnect the battery or generator.
Use a 12 volt regulator matched to the polarity that you choose. You can rebuild the generator to produce 12 volts and it will look like the original ginny.
The wiring diagram is in the parts book.
I just converted mine to 12volt. I like using a one wire alternator then all u have to do is run a wire from alt to bat its real easy. I used two pieces of angle iron on the bottom of the alt about 3 inches long and the original top tension-er. you will have to change the coil and lights but other than that nothing else. the amp meter will work to. It cost me under a 100$ for everything not including a 12 volt battery. Jason
Yeah, 12v on a 6v starter will really put a lot of strain on it. Might want to have the starter rewound for 12v....
Later!
Later!
- Willyr
dont forget.... the 12 volt alternator requires NEGATIVE ground. You will need to change your lights too including the one in your dash for 12v.
former owner of a 1956 420c
- mapaduke@yahoo.com
I'm working on a late 440 witch someone changed over to 12v.The starter has a stud whair the switch would have been mounted and with a wire going to a starter solenoid off of it.would it have been converted to 12v?
Also what GM cars used the 12v points that fit thies distributors?
Thanks Ron.
Thanks Ron.
nothing crawles like a deere
- Willyr
most anything of pre 1972 used points, I am guessing to try a c-10 pickup with a 262 motor.
The button often gets butchered to a stud to afford the solenoid. Resoning easier to push a button than it is to pull a knob. The original starter switch does burn out and what I gather is people feel it is easier to use a new style of solenoid, so they butcher it to a stud. You can get a stud replacement, but not go back to the button
. Mind you a 6 volt solenoid can be used on 12 volt. But a 12 volt solenoid wont work at all on 6 volt.
- JD440ICD2006
I believe that the switch offered then was simply an ignition interrupt. My 440IC has that switch and it just turns the power on and off, still have to pull the knob going to the starter to get it started.
It is a keyed switch that keeps the honest people honest, but is easy to over ride if you want to start it.
- Willyr
When I had to rebuild the instrument panel on my tractor. The wire that comes out of the fuse now goes through the switch. This includes the power for the starter button.
So now when I go to a fair I can with peace of mind turn off the key and remove it from the ignition. So that if some ones junior decides he wants to sit in my tractor, he cant accidentally bump it while in gear.
Users browsing this forum: No registered users and 9 guests
