3PT hitch for sale
3PT hitch for sale
Post by Lavoy » Wed Apr 19, 2006 10:14 pm
Listing for a friend, 3PT hitch, nice shape, several new parts. Does not have top link, or correct sway chains and clevises.
Hitch is located in ND, any questoins, let me know and I will get you the answer from the owner.
shinnery
Post by shinnery » Thu Apr 20, 2006 3:32 pm
This is more idle curiosity than anything else after the IRS got thru with me. But what tractors/crawlers will it fit and is it compatable with a 831 loader on a 440ICD?
Post by Lavoy » Thu Apr 20, 2006 4:53 pm
Bryce,
I believe it is now sold, but I might have another one in a month or so.
These hitches fit 40 after 62,263 up through 440. They will fit on a loader, but require some more thought in the installation. There is no way to mount the cylinder bracket. I have seen pics of them on a 90 loader, and they weld a tab on the loader frame to hook the cylinder to. Other problem is lack of hyd to run it. It really should not be hooked into the loader hyd unless you use a pressure reducer. The loaders operate at a higher pressure, and would increase the lift capacity too much.
Post by Lavoy » Thu Apr 20, 2006 8:17 pm
The 3PT is sold, thanks.
