350 broken case
chris
350 broken case
Post by chris » Fri Apr 14, 2006 8:37 pm
Iam looking at a 350 dozer, the case that has the shifter and the steering levers attached to it has broken off the (trans??) case ahead of it. Not sure of the arrangment of components that Iam looking at here-I have never worked on a dozer before. Anyways that case is broken bad and needs replaced, how much should the part be and where could i find one???And how much is it worth the way it sits, wont move but the blade hydraulics work, rt track adjuster wont hold, has a winch,rops,6 way blade, he is asking 6000.00 . Thanks.
Post by Lavoy » Fri Apr 14, 2006 9:36 pm
Not sure I understand fully which case you are referring to, but it is either the trans or reverser case. Either way, lots of work, and probably lots of money. For $6000 look elsewhere.
lavoy
chris
Post by chris » Sun Apr 16, 2006 10:40 am
It is the second case from the engine, looks like the shifter and steering levers go in the top of it. Maybe someone has a manual with an exploded view??? Thanks.
Post by Lavoy » Sun Apr 16, 2006 6:49 pm
That is the tranny case. I would look for a different crawler. Only way to fix that one is complete disassembly of the crawler all the way to the tranny case. That is why he is selling it instead of fixing it.
JD430C
Post by JD430C » Mon Apr 17, 2006 1:15 pm
chris, i agree with lavoy u should find another crawler. i completely disassembled dads 350 because all the bolts holding the reverser to the tranny broke. took me a month to take it apart and put it back together. i do have a tranny if u are set on this 350. pm me if interested.
andrew
