JD Engine Lifting Eye
Johndozer
Post by Johndozer » Thu Jan 27, 2011 3:23 am
Looking for a JD engine lift hook or eye.
Attaches/screws to one of the valve cover studs.
Willyr
Post by Willyr » Thu Jan 27, 2011 9:08 am
Go to a Chevy dealer. Very common part for 305's like $5 each. Otherwise it is a 3/16 piece of steel with a 1.25" hole on one end and a .375" hole on the other and about a .5" web between the 2 holes.
Junkyard could sell you a pair for $5?
former owner of a 1956 420c
Post by Tigerhaze » Thu Jan 27, 2011 10:03 am
I thought the smallblock Chevy lift rings attached to the intake manifold bolts rather than the valve cover studs? I suppose you could still get it to work though.
Scott Corbett
Post by Scott Corbett » Thu Jan 27, 2011 11:36 am
I believe you are right. They looked like a bent bracket and did attach to the intake bolts.
John Deere 1959 440IC Loader
Post by Lavoy » Thu Jan 27, 2011 2:12 pm
The factory eyelet only hooks to the front stud. It is 7/16" NF female thread.
Or, just take a flat piece of strap and drill two holes in it so you can lift from two studs instead of one. Weld another piece perpendicular to the first with a hole to hook your chain hoist to.
Users browsing this forum: No registered users and 81 guests
