430C frt pump....no parts!!!!!! Lavoy?
Bobmn
Post by Bobmn » Tue Jan 25, 2011 5:07 pm
Hello to all; need this dozer in the woods!! You all know how these things start! Alt stops.....smokes the belt. Back to the shop, to tear it down. The frt pump was kinda weak, and as long as you have it off.......you might as well get it fixed! Then, the hyd. shop called and said it does NOT look good for parts. And its really a short space the pump fits in. And the six spline is hard to find!? I can change the pulley drive to fit the pump, I guess! Any one used a newer pump to replace the old one? If so, where was a pump found? Lavoy, do you know or have rebuild kits? Thanks Bobmn
Post by Lavoy » Tue Jan 25, 2011 6:37 pm
Are you talking a crank pump for a loader, or a cam pump for a dozer?
Bobmn
Post by Bobmn » Tue Jan 25, 2011 7:13 pm
Lavoy; Geez.......It's for the crank Thanks Bob
Post by Lavoy » Wed Jan 26, 2011 10:03 am
All the parts are available, but real pricey if you get in very deep. I think the input shaft alone is over half the price of a new pump.
Bobmn
Post by Bobmn » Wed Jan 26, 2011 12:30 pm
Lavoy; Do you stock new pumps?....or know where to get one? Thanks Bob
Post by Lavoy » Wed Jan 26, 2011 2:07 pm
I do not stock them, I can check on current price if you want. I assume you have a Hydreco now?
Bobmn
Post by Bobmn » Wed Jan 26, 2011 3:31 pm
Lavoy; Yes, I do have Hydreco pump...6 spline shaft and coupler, which I should replace also....maybe the pully coupling too. They are wore also. Thank you again. Bobmn
Post by Lavoy » Wed Jan 26, 2011 4:25 pm
PM sent.
Users browsing this forum: No registered users and 194 guests
