more 420c questions
redkneckracer
more 420c questions
Post by redkneckracer » Thu Jan 06, 2011 6:48 pm
need to set the record straight with some friends. i have 420c serial # 110449 and her blade push arms are mounted on the outside of her track frames not inside... and the hoist cylinders stroke out to drop the blade not to lift it. this is not original for this year 420c is it? lavoy can probably tell me the year of this rig aswell but i thought these machines had the push arms inside the track frames?
Post by Stan Disbrow » Thu Jan 06, 2011 7:24 pm
420's were equipped with both inside-mount and outside-mount blades. Not all of them are Deere blades, though, as there were a lot of 3rd party blade makers.
The cylinders are meant to provide downforce on a dozer, so they all stroke out to lower the blade.
Later!
Post by Lavoy » Fri Jan 07, 2011 12:36 pm
There were several manuafacturers that made this type of blade setup. If you think it is a Deere blade, it is a 602.
boler76
outside mounted blade arms with outgoing piston for down
Post by boler76 » Fri Jan 07, 2011 4:19 pm
That is exactly the same setup as on my 40c
Swawpy
Post by Swawpy » Sat Jan 08, 2011 10:12 pm
Your blade sounds just like whats on my 40c...mine happens to be a holt blade.
Users browsing this forum: No registered users and 671 guests
