steering clutches
Post by Stan Disbrow » Sat Dec 25, 2010 9:55 am
So, there are steel driving discs as well as fiber for the dry-clutch packs? I have never seen a steel driving disc that wasn't meant to be in an oil bath. Interesting.
How do the steel versions last with respect to the fiber ones?
Later!
drf1232000
Post by drf1232000 » Sat Dec 25, 2010 12:16 pm
I appreciate all your help here in the forum. Being new to the world of crawlers I'm glad to get all the info I can. I had hoped it would be just learning how to operator the thing. I guess I'm all in now, with it all apart on the shop floor.Should be like new come spring.. Just like working on my CJ only bigger and heaver
Will trade electrical work for help with JD350 repair work
Dwight Flemming
lp14255
Post by lp14255 » Wed Dec 29, 2010 6:07 pm
wanted to know if Lavoy had the template for setting the pressure plate on my 350
1969 jd350 crawler dozer
Post by Lavoy » Thu Dec 30, 2010 10:00 am
Yes I do, they are $30 with freight.
lp14255
Post by lp14255 » Thu Dec 30, 2010 1:05 pm
i'm changing out the clutchs on the left side only , should i do the right side also since i'll have the whole back half of the crawler torn down.
lp14255
Post by lp14255 » Thu Dec 30, 2010 1:21 pm
lavoy do you also have power steering booster kit part # AT27076
Post by Lavoy » Thu Dec 30, 2010 9:11 pm
Not on hand, but easy to get.
lp14255
Post by lp14255 » Mon Apr 11, 2011 3:42 pm
how much does the kit cost?
Post by Lavoy » Mon Apr 11, 2011 7:03 pm
Don't remember for sure, in the $40 range I think.
