jd 350 with winch, value and infor
switchhappy
Post by switchhappy » Tue Oct 19, 2010 9:28 am
well iv had many crawlers and my last was a 310g case, and befor that was a 440 jd , im trying to work up to a 450, i found a jd 350 with a winch and 6 way blade, it has the disel in it, the guy just re did the trans and it needs to be pt back in, so what im needing to know is whats it worth and weight and hp range, man said i can have it all for 3500, is this a strong dozer, , i mainly do pond dressing and fence rows, but mainly want it for my land to log ciders trees, im in ky also, ay help would be nice
350c 6 way blade, winch, log arch,,, current 3 year project of being saved and put backgether.. HELP
Post by Tigerhaze » Tue Oct 19, 2010 9:36 am
Here is the spec sheet for a straight 350 crawler loader- the dozer will weigh a little less but the HP will be the same as will many of the other specifications.
http://www.murphyused.com/images/specs/84.pdf
Worth is based on many factors such as location, condition of the machine, market conditions, etc. In my area, $3500 would be a great price for a working 350 with a 6 way blade and working winch but since this crawler is in pieces you will need to take that into account.
switchhappy
Post by switchhappy » Tue Oct 19, 2010 9:55 am
yea see iv done this on a 440 jd only that one i had to do the trans my self, this one is done and just needs the trans put back in, and the winch mounted back,, is the later 350 like a b or a c worth more or biger motor wise,, and what all can this crawler do, like its biger then a 440 jd and hever right, is the 350 dependable
switchhappy
Post by switchhappy » Tue Oct 19, 2010 11:05 am
so is the 350 c the last they made and were is the plate on one of these,
Post by Tigerhaze » Tue Oct 19, 2010 12:40 pm
This thread should help you some on the features questions:
http://www.jdcrawlers.com/messageboard/ ... light=350c
There are a number of other informative threads on this bulletin board if you care to search for them.
switchhappy
Post by switchhappy » Tue Oct 19, 2010 2:07 pm
thats what i been doing all day, lol :)
switchhappy
Post by switchhappy » Tue Oct 19, 2010 5:48 pm
ok guys its mine now.. lol.. well all 50 pices of it... has all new under carage and rollers and a big winch,,,lol.. well i need to know on the model, the tag said jd350CE... does that make it a 350c right? and i gess it has wet clutches, it has two lines on each side of the trans near were the finels bolt on.. i dont see no clutch packs like a 440.. so what style does it have?......anyone have a brake down of the the rear end,, i have the cd ordered
Post by Lavoy » Tue Oct 19, 2010 8:17 pm
If it is wet clutches, it is a C model alright. Get both factory parts and service manuals prior to assembly, you will need them.
The clutches are the same concept as a 440, they just run in oil.
switchhappy
Post by switchhappy » Wed Oct 20, 2010 10:37 am
i just rember my 440 haveing a pressure plate and clutches with a throw out bering, i dont see this on this unit, i see a different style set up, it has the final, then a open case that bolts to that then all that bolts to the trans?
Post by Tigerhaze » Wed Oct 20, 2010 10:52 am
switchhappy wrote:well i need to know on the model, the tag said jd350CE... does that make it a 350c right?
If you have the serial number tag, you will be able to narrow down the year by the serial number range:
http://www.jdcrawlers.com/messageboard/ ... php?t=2410
BTW, the "C" after 350 in the serial number stands for crawler. It sounds like you still have a "C" or newer model due to the wet clutches, but could be a newer model like the "E". You will know for sure by the serial number range itself since it is sequential by year.
See the relevant post below- Digitup is pretty knowledgeable about the 350 and 450 series crawlers.
Post by Stan Disbrow » Wed Oct 20, 2010 1:39 pm
The 350 series only went up as far as the 'D' series, so the 'CE' can't stand for it being Crawler, E-series.
There was an 'economy' variant for the B-series that I recall. Perhaps this is what the 'E' means.
Not that I know what one did not get on the machine to make it a less costly Economy variant. No power steering? No reverser? Manual blade?
Anyway, at some point, the 'C' meaning Crawler was dropped from the serial number plates, but I really do not know when that happened.
I have seen '350C' on early straight 350's, where the 'C' clearly means crawler. I've also seen '350CB' on later 'B' series 350's where, again, the 'C' means crawler.
But, then, I've also seen '350C' on 350's with wet steering clutches where the 'C' must refer to the series, not the fact it's a crawler.
Maybe it's a case of, when they got to the 'C' series, someone decided that stamping '350CC' on the plate looked weird and so they used only one 'C' for the series and dropped the 'C' for Crawler at that point.
My problem is that I have not seen enough examples of JD350 serial number plates to know just what was going on when. What we need is for the guy that stamped plates at Deere to become a member and tell us! :P
In this case, if the machine has wet steering clutches, then I'd say that the plate is trying to tell us it's a 350 crawler, series 'C', Economy variant.
Later!
DBCSteve
Post by DBCSteve » Wed Oct 20, 2010 6:20 pm
Stan Disbrow wrote:Hi,
In this case, if the machine has wet steering clutches, then I'd say that the plate is trying to tell us it's a 350 crawler, series 'C', Economy variant. Dry clutches of course.
Later!
To make it even more confusing, my former 350B had "350BE" on the plate. It was a standard 350B with 6-way 6305 blade, standard JD rippers, dual cylinder power steering and reverser. Nothing that would indicate "economy" (but the 6405 blade on my 450C is MUCH BETTER in design than the 6305). The serial number was 126738T.
Steve
JD 450C, Serial No. 316559T
Kubota L3400 top-n-tilt
switchhappy
Post by switchhappy » Wed Oct 20, 2010 8:00 pm
ill get the serial number tomarow if i can , i know the sides of the dozer has 350 c on it, and it has a reverser and a power 6 way blade
switchhappy
Post by switchhappy » Fri Oct 22, 2010 6:03 am
the serial number on my box said 29890t whats that make it?
KenP
Post by KenP » Fri Oct 22, 2010 7:32 am
deleted
Users browsing this forum: No registered users and 254 guests
