JD 440C Engine Swap ??
Ricky Sims
Post by Ricky Sims » Mon Mar 27, 2006 11:19 am
I have found a 440 diesel crawler that the engine is down, I would like to know if a gas engine will bolt in or does it require changes in the bellhousing,clutch,hydraulic pump drive,etc. ?? If you know where I could buy a complete gas or diesel engine that is in good condition, that will bolt right in I would like to know where?
Post by Lavoy » Mon Mar 27, 2006 2:46 pm
You can put a gas engine back in it, but you better have a gas donor crawler sitting there to take parts off of, it will take a lot more than just the engine.
Ricky Sims
Post by Ricky Sims » Mon Mar 27, 2006 2:51 pm
Sounds like I need to find a diesel engine, or some parts for the one that is in it. It has a 2-53 Detroit in it, any suggestions on where to start looking?
Post by Lavoy » Mon Mar 27, 2006 7:15 pm
Detroit parts are easy to come by, what do you need?
lavoy
Ricky Sims
Post by Ricky Sims » Thu Mar 30, 2006 8:46 am
I need the complete Blower everything else can be repaired.
Post by Lavoy » Thu Mar 30, 2006 2:10 pm
2-53 blower should not be hard to come by, there are a lot of them around.
Ricky Sims
Post by Ricky Sims » Fri Mar 31, 2006 1:07 pm
I appreciate the help and information, I have located the parts I need to put this crawler back in good running condition.
Users browsing this forum: Google Adsense [Bot] and 257 guests
