lp14255
Post
by lp14255 » Sun Oct 17, 2010 6:58 pm
i have a 350 crawler and im going to be replaceing my steering clutchs soon, found alot of oil inside the housing . what are all the parts i need to do this the right way. i also need the parking brake latch.
1969 jd350 crawler dozer
bonker81
Post
by bonker81 » Mon Oct 18, 2010 5:53 am
Lavoy is all you need. I just re-built both sides this summer. Have fun.
1970 350 with a 93A backhoe attachment
- Site Admin
Post
by Lavoy » Mon Oct 18, 2010 8:43 am
You need to find the source of the oil and fix that first. No sense ruining new clutches with oil contamination. I would guess that you need a new pinion shaft seal, but it is possible it is a carrier seal as well.
A steering clutch kit runs about $630.
Paul45
Post
by Paul45 » Mon Oct 18, 2010 9:25 am
I just did mine, the seal's going into the final was bad. Made a mess of everything. i used oven cleaner and power washed it off worked great. my 350 (older) used two seals. I bought everthing from Lavoy, great guy with ALOT of info. I would be glad to tell you how i did mine email me with your phone #
paulc@dimarmfg.com
thanks Paul
350 track loader, 350 dozer
lp14255
Post
by lp14255 » Mon Oct 18, 2010 5:51 pm
the control valve for the blade was leaking oil down on the inspection plate, didnt think it would hurt, come to find out , their where no gaskets on the inspection plates and oil got inside the clutch housing. if i do one side should i do both.
lp14255
Post
by lp14255 » Mon Oct 18, 2010 5:56 pm
should i get the john deere clutchs or the after market . the salesman at my local nortrax said the after market was as good just half the price at $24 dollars
- Site Admin
Post
by Lavoy » Mon Oct 18, 2010 7:56 pm
I have sold several thousand of the aftermarket discs, other than one particular brand that I no longer carry, I have had no trouble.
lp14255
Post
by lp14255 » Tue Oct 19, 2010 8:25 pm
lavoy do you sell the clutch kit for the crawler i have.
- Site Admin
Post
by Lavoy » Wed Oct 20, 2010 10:00 am
Yes I do, normally I have multiples of each piece in stock, occasionally I am out of stock on one or the other pieces due to the amount I go through, but short time to restock.
lp14255
Post
by lp14255 » Wed Oct 20, 2010 7:01 pm
how much do you sell them for
- Site Admin
Post
by Lavoy » Thu Oct 21, 2010 9:12 am
Depends on which piece, full kit runs about $630.
lp14255
Post
by lp14255 » Fri Oct 22, 2010 7:39 pm
how do i find the master pin to take the chains and pads off.
KenP
Post
by KenP » Sat Oct 23, 2010 4:32 am
deleted
KenP on Thu May 30, 2013 1:49 pm, edited 1 time in total.
lp14255
Post
by lp14255 » Sat Oct 23, 2010 6:06 am
thanks for your help i'm going to need all that i cant get. thanks again
lp14255
Post
by lp14255 » Mon Nov 08, 2010 7:07 pm
on the clutchs should i get the fiber or metallic discs .
Users browsing this forum: No registered users and 32 guests
