350 final MESS
Paul45
350 final MESS
Post by Paul45 » Sat Aug 21, 2010 4:36 am
I removed the final and found a black sticky oily mess, everything was coated. the shaft from the trans which goes through the throw out bearing has ALOT of play in it, i can move it up and down almost a 1/4 inch.
can someone tell me what is wrong? can i get to this shaft bearing and seal with removeing the casing that the throw out bearing shaft is in?
Can someone tell me what they found to clean the black oily mess off of these parts? I sprayed almost a can of carb. cleaner and it did not do much. thanks Paul
thanks Paul
350 track loader, 350 dozer
Post by Lavoy » Sat Aug 21, 2010 7:27 am
Get a couple cans of Easy-off oven cleaner, not the low odor stuff, the really smelly gas mask kind. Spray it on, let is work for a while, rinse off with hot water and repeat as necessary. The other option is some of the engine degreasers, or something like Simple Green. The problem is, that old gear lube, mixed in with brake/clutch dust, and whatever dirt got in there, makes a really big mess. If you have access to a steam cleaner, that is the best option. A
Paul45
help
Post by Paul45 » Sat Aug 21, 2010 1:27 pm
I removed the throw out bearing and shaft, shaft looks ok.
where does this oil come from? the final or the transmission?
thanks paul
thanks Paul
KenP
Post by KenP » Sat Aug 21, 2010 2:27 pm
deleted
Paul45
Post by Paul45 » Sat Aug 21, 2010 2:51 pm
Can i replace this seal with out pulling clutch housing? on the transmission side?
can we still post pics ? can someone tell me how? Thanks for your help!!
thanks Paul
Post by digitup2 » Sat Aug 21, 2010 7:18 pm
What do you have for a crawler?OK I know it's a Deere!! but size and series are what I am after.Digitup.
Paul45
Post by Paul45 » Sun Aug 22, 2010 5:16 am
Sorry i have a 350 crawler loader straight 350 with reverser. Thanks paul
thanks Paul
Users browsing this forum: No registered users and 222 guests
