350 leeking from reverser to trans
jaybuilt
Post by jaybuilt » Thu Jul 15, 2010 9:19 am
Hi all.I am new to the form and need to find out ware the leek might be.thank for the help jaybuilt
Post by Lavoy » Thu Jul 15, 2010 11:36 am
About the only possibility is the out put shaft seal.
jaybuilt
Post by jaybuilt » Thu Jul 15, 2010 4:51 pm
thank you for the quick responce Lavoy.I just removed the reverser and it wasant wet on the output of reverser or input of trans. the shafts feal good on the runout.the owner siad that in a few hours runing the reverser would be 2 qts low and start to act up. the trans oil level would be over so he had a gear lube pump that he used to pump it back into the reverser.he had been doing that for a number of years.i came into the picture when motor was out so i didnt see it for myself.this is the first one i have workted on and dont know alot about them.it looks like the pump for the rev is also used for stearing clutches. is that right ?
Post by Lavoy » Thu Jul 15, 2010 10:38 pm
If so, you must be talking about a C model with wet clutches?
jaybuilt
Post by jaybuilt » Fri Jul 16, 2010 1:25 am
yes lavoy it is a c model sorry i should have siad that in the first post http://www.flickr.com/photos/46123265@N03/4798702314/
Post by Lavoy » Fri Jul 16, 2010 7:49 am
Then I would have to plead ignorance, not enough experience on that one. I have heard reasons for it though, someone on here will know the answer.
jaybuilt
Post by jaybuilt » Sat Jul 17, 2010 1:09 pm
I am thinking that the stearing controle valve is leting oil by and it is going into top of trans.any thought on this guys ?and is their a recomended parts house for trans imput shaft and misc/seals.
thanks for the help JAYBUILT
CatD8RII
Post by CatD8RII » Sun Jul 18, 2010 12:28 pm
It could be your steering clutches. On C models the clutches are oil applied and spring released. They use reverser oil pressure to keep them applied. Pulling back on your steering lever blocks that oil off. You may have a leaky piston or a supply tube. How does the machine push? If you have an air regulator you can pressurize the clutches with a small (10 PSI) ammount of air at the inlet on the steering control valve. Then you unhook your supply and wait about 10 minutes to see how much the pressure drops. (One note of caution: make sure the steering lever linkage is still attached to your conrtol valve or else the spools pop out!!!).
jaybuilt
Post by jaybuilt » Mon Jul 19, 2010 2:04 pm
thanks CATD8.i will look at the pistons today great tip on spools .how about a good used/new input shaft any ideas wear to look ? other than JD
what a big help you all are .i love the hole internet thing for this varry reason.
jaybuilt
Post by jaybuilt » Sun Aug 15, 2010 6:27 pm
thanks all i found the leek at the clutches and pistons thanks again saved me a lot of time and thanks
Users browsing this forum: Bing [Bot] and 25 guests
