420 crawler serial numbers and production figures
Facts and knowledgebase about John Deere crawlers
Post by Lavoy » Thu Apr 14, 2005 4:39 pm
1956-80,001-94,818
1957-100,001-119,764
1958-125,001-136,868
Total 420 crawler production-17,882
Total by year:
1956-5386
1957-9498
1958-2998
lavoy
dewrideyz
ID numbers
Post by dewrideyz » Sun Sep 11, 2005 10:48 pm
Where is the serial number located....I just bought a crawler and have no idea what year it is....Im guessing its 420 1953 or 3 from the pictures i saw....
Jimmy in NC
Post by Jimmy in NC » Sun Sep 11, 2005 11:10 pm
Tag should be located on the left side as you sit on the tractor under the fuel outlet on the fuel tank. It should be rivited to the centersection.
In the picture here it's about dead center under the fuel line.
Hope that helps you some.
Jimmy in NC
dewrideyz
ID numbers
Post by dewrideyz » Sun Sep 11, 2005 11:28 pm
thx for the quick reply...the plate is missing BUT the crawler u pictured is it.....looks the same anyway, could u post some more pics for me to look at? It came with a scoop but no blade. It has a heavy steal grill with horizontal louvered bars, two pedals that engage together? It has the same track as the crawler u posted. The extra head with it has the casting # M1768T. Its a 4 spd + reverse....is there anything i can tell u to help ID it? thx Aaron
Jimmy in NC
Post by Jimmy in NC » Mon Sep 12, 2005 5:19 am
Dewy-
If you could get some pictures it will help more than me posting pictures of my machine.
Others on the board with more experience than I would probably be able to look at the pictures and tell you more. Remember the MC, 40C, 420C all were really close in appearance... especially at a distance.
Jimmy in NC
CPeter
Post by CPeter » Thu Sep 21, 2006 6:21 pm
One thing I can tell you is that the two pedals are NOT supposed to work together. the left is the clutch and the right is the brake. They work on a co axial shaft (one inside the other) and frequently seize up. PB Blaster squirted onto each side and then trying to work the pedals seperately may get them up seized. I put the Blaster to mine on a regular basis to keep them free. This is a very common problem.
CPeter
40C, 420U, Dubuques for 35 years
jdcollector
Post by jdcollector » Sun May 02, 2010 6:43 pm
Do you know what the sn. is for the first and last 420C off the line was?? I know the 430C were numbered differently that the wheeled 430's but the 420's were all in the mix.
Patrick Thomson
440 ICD w/ 831 Loader
420C w/ 62 Blade
Post by Lavoy » Sun May 02, 2010 8:20 pm
First 420C- 80,002
Last 420C-136,795
430 crawlers were numbered in the same range of serial numbers as the wheel tractors, same as the 420's, only the 40 did not follow this rule.
jdcollector
Post by jdcollector » Mon May 03, 2010 12:47 am
Ok, good thing to know. Thank you! Do you know how I could figure out how far from the end of production a certain 420C was??
Patrick Thomson
420C w/ 62 Blade
CELSESSER
Post by CELSESSER » Mon May 03, 2010 6:09 am
Pat,
go to the top of this thread where Lavoy gives the searial numbers by production year. I think that is as close as you can get. average the years production volume per month and you will be close.
Chuck
Steven Walters
LP
Post by Steven Walters » Sun Apr 16, 2017 9:25 am
Any LP crawlers ever built?
Post by Lavoy » Sun Apr 16, 2017 4:55 pm
Four 420 not sure how many 430.
Canuck 420c
Re: 420 crawler serial numbers and production figures
Post by Canuck 420c » Sat Jul 30, 2022 10:33 am
What are the production figures for each year of the 420c?.I would like to know how many series one 420c's were made?
Nothing Crawls Like a Deere
Post by Lavoy » Sun Jul 31, 2022 8:39 pm
First post in this thread.
Canuck 420c
Post by Canuck 420c » Mon Aug 01, 2022 5:32 pm
Thanks i noticed that after i made the post :oops:
