1964 1010c
Jamie/1010/ontario
1964 1010c
Post by Jamie/1010/ontario » Tue Feb 21, 2006 9:09 pm
Help:
My son 'helped' clean out the garage last week and proceeded to throw out the filter assembly and housing for the hydraulic system on my 1010c crawler with an 850 loader. The piece that I am looking for mounts both filters and bolts to the top of the hydraulic system tank mounted on the left side of the machine beside the operators position. Any help in locating one would be greatly appreciated as the machine is completely useless without it. I will call the region tomorrow to see if I can get into the dump to look for it however it has been almost 5 days now and I live in a city of 500,000 people. I mean how much garbage could be piled on it in a week? Can't be that bad.....help!
Jamie :(
JD430C
Post by JD430C » Wed Feb 22, 2006 11:10 pm
jamie, if u dont find one email me. i might have one.
andrew
digitup
Post by digitup » Fri Feb 24, 2006 8:59 pm
James if you are still having problems finding that unit get in tuch with me a local tractor wrecker has those filter parts and Iam not far away from you Ilive in Wingham Ontario so there are equpiment wreckers by the dozens between us Is the filter the same on a 1010 teactor as the crawler version? I had one of those and sold it hours after purchace to a old fellow in Moriston Ont so I dont remember much of that filter If you have a parts book look up the part number. Digitup
Tiny Crawler
Post by Tiny Crawler » Sun Feb 26, 2006 5:38 pm
Jamie,
Let me know if you still need the part, there is a tractor salvage yard down the street from me and there are two 1010 crawler loaders there that I have been scavenging parts from.
I am assuming it is the filter stack that is held down into the reservoir by four bolts. I can look in my PL and photocopy the part and confirm it before it is removed.
tiny,..
