Changing to deluxe seat on crawler with 3 point hitch
Will i have any mounting problems taking off the normal crawler seat and putting a deluxe seat on one with a 3 point hitch. Should i just take off frame under the original seat on put this on the deluxe seat. I have one deluxe seat with nothing under it and another one that came off a normal 1010 crawler with no 3 point.
- JD440ICD2006
I was thinking that I read where the Deluxe Seat was not an option if the factory 3 point was ordered, could be wrong.
Deluxe seat
Jay.
According to JD sales literature of the time the deluxe seat was not
available as factory equipment with the three point hitch.Lavoy says
he has adapted some so it's possible,just don't look for factory parts
as a strict bolt in.JimAnderson
Real easy to do, done it on several. You will need to make some spacers to set the seat up higher. Also, depending on how long your legs are and how far back you want the seat, you can get the toplink to hit the back of the seat. I have seen a couple deluxe seat where they torched the back of the seat out because of this. I just set the stop on the cylinder so the hitch does not come up as high.
- JD440ICD2006
While you are "fabbing", you could also build something on the back of the deluxe seat to hold the top link up when not in use.
- JD440ICD2006
It would be great to see pictures of the project as you can provide them.
Users browsing this forum: No registered users and 231 guests
