Changing to deluxe seat on crawler with 3 point hitch
jay563
Post by jay563 » Fri Feb 05, 2010 5:38 pm
Will i have any mounting problems taking off the normal crawler seat and putting a deluxe seat on one with a 3 point hitch. Should i just take off frame under the original seat on put this on the deluxe seat. I have one deluxe seat with nothing under it and another one that came off a normal 1010 crawler with no 3 point.
Post by JD440ICD2006 » Fri Feb 05, 2010 6:24 pm
I was thinking that I read where the Deluxe Seat was not an option if the factory 3 point was ordered, could be wrong.
JimAnderson
Deluxe seat
Post by JimAnderson » Fri Feb 05, 2010 7:40 pm
Jay.
According to JD sales literature of the time the deluxe seat was not
available as factory equipment with the three point hitch.Lavoy says
he has adapted some so it's possible,just don't look for factory parts
as a strict bolt in.JimAnderson
jay563
Post by jay563 » Fri Feb 05, 2010 9:29 pm
I figured as much as i could not find any such information on that type of mounting in the parts book, it probably won't be too hard to modify though.
Post by Lavoy » Sat Feb 06, 2010 10:52 am
Real easy to do, done it on several. You will need to make some spacers to set the seat up higher. Also, depending on how long your legs are and how far back you want the seat, you can get the toplink to hit the back of the seat. I have seen a couple deluxe seat where they torched the back of the seat out because of this. I just set the stop on the cylinder so the hitch does not come up as high.
Post by JD440ICD2006 » Sat Feb 06, 2010 12:01 pm
While you are "fabbing", you could also build something on the back of the deluxe seat to hold the top link up when not in use.
jay563
Post by jay563 » Sat Feb 06, 2010 1:44 pm
Thanks for everyone's feedback and help with this.
Jason
Post by JD440ICD2006 » Sat Feb 06, 2010 1:48 pm
It would be great to see pictures of the project as you can provide them.
Post by Lavoy » Sat Feb 06, 2010 6:20 pm
There actually was a toplink bracket made for the 1010 to hold the toplink. The handle on toplink is different to work with the bracket, but that could be changed as well.
Users browsing this forum: No registered users and 254 guests
