battery
willy wagon
battery
Post by willy wagon » Wed Jan 06, 2010 9:55 pm
considering the starter, and cables are in good cond. what size amp. batt is recomended on the 440 crawler?
Post by JD440ICD2006 » Wed Jan 06, 2010 11:13 pm
Depends on which one you have. The 440IC (gas) was 6 volt from the factory. The 440ICD (diesel) was 12 volt from the factory.
I would say that any battery over around 650 CCA would be OK. It also depends on how cold it is where you are and the condition of the engines, especially if it is the 2-53.
shinnery
Post by shinnery » Thu Jan 07, 2010 1:04 am
I use a group 31 12Volt battery in my 440ICD, I figure if it will start a 12 valve Cummins in a Dodge truck it might start a 2-53 Jimmy.
Post by JD440ICD2006 » Thu Jan 07, 2010 7:17 am
Bryce,
Does your 2-53 have the "N" kit? I am thinking of having mine upgraded pretty soon.
I have been told by many that it helps with starting.
Post by Lavoy » Thu Jan 07, 2010 9:44 am
Probably no comparison between and S engine and an N engine. It is about a 4 point jump in compression, plus you should install the N series injectors as well. I had one 440 that would start without ether in the high 20's, most won't start in the high 60's.
shinnery
Post by shinnery » Sun Jan 10, 2010 11:48 pm
I feel sure my 2-53 is the same as it left the "Detroit" factory in 59. Every time I think of a 'Detroit" engine I remember about 40 years ago I was at a BIG truck shop in Dallas getting a set of rear springs re-arched for one of my many Mopars. There was a Pherd cabover in there getting some work done on the front axle, just happened to notice the "jimmy" 6-71 engine in it and said something to the driver about it. He was very sure it was NOT a "jimmy" 6-71 but a "Detroit" 6-71 in his Pherd truck. I thought A l l r i g h t, sure, and didn't say anything else.
:roll: :shock: :D
Users browsing this forum: No registered users and 191 guests
