I have a JD 350C - it would not move, now it will move but has no pushing power. Steers fine, reverser works fine,(little jerky). Fluids are full but I do not know if any of the tran-final drive or reverser filters have been changed. Please give me some direction.
Thanks,
Acepilot
Weak JD 350C
BSims66173
Several things to check are: make sure there is no trash, sticks or limbs keeping the clutch lever from returning all the way. Replace filter if you do not know the condition of it. install guage and check reverser pressure. I had the same issue on my 350c. I found that my reverser would only build about 50psi. It should be around 120psi. You can look at this post to see what I found when I went into my reverser. The problem was with the clutch arm in the control valve being worn. You can see in the pics how it was worn and I just made a new one. It now has good pushing power.
http://www.jdcrawlers.com/messageboard/ ... php?t=3959
Barry
Barry
350C has no pushing power
Thanks for the information. I will check the items. You did a very impressive job on your machine. A+++
Thanks Again,
Acepilot
Thanks Again,
Acepilot
BSims66173
Users browsing this forum: Google [Bot] and 94 guests
