440IC Transmission fluid change
Can someone tell me where the transmission filler and drain locations are? Do I have to take off footrests or the skidplate to access them? Also, is there a dip stick or other mechanism to determine the level of lubricant in the tranny?
JD 440IC 2 CYL Gas Crawler Dozer with a 6 way blade. Serial Number 442495
THX for the information Lavoy. The serial number for my 440ic is 442495 so my tranny drain would be on the belly more or less under the left footrest area and the fill port would be under the right footrest if I understood your reply correctly. Do you normally have to remove the right footrest to fill the transmission? What type of lubricant is recommended and how often should it be changed? THX MUCH for your help.
Users browsing this forum: No registered users and 216 guests
