On a 450, how does the track come apart? I've beat and beat on what I think is the "master" pin and it hardly moves at all with me hitting it with a 20lb hammer. I've hit and hit and so far it's only moved about 1/8 inch.
I didn't see any pins at all that had maybe a "C" lock pin.
how to take track apart
I finally got the track apart after hours of beating. I never did see a pin with a clip on the backside and I turned the track around and visually looked and cleaned every single pin and still no clip. The only thing different about the pins was one had a hole in the ends of it both on the inside and the outside. It was a small hole about 1/8" in diameter.
Should I get a pin with a clip on the back to go back in or just beat that pin back in when I finish?
Users browsing this forum: No registered users and 236 guests
