final drive seals 420c
homer420c
Post by homer420c » Thu Jan 26, 2006 10:20 pm
I ve now torn down my 4 final drives( 2 from my parts 40c) and salvaged the best pieces to use as I reassemble. Each of the 4 pieces had its own story.
One had 90wt that was thicker than tar and blacker than a dark hole,but the gravel in it was all less than 1/4 inch.
Another had lube in it at one time,but there was nothing to drain.
The third one had been full of water,probably many seasons,but had frozen the bottom case,and managed to keep itself drained.
My favorite,the fourth, also had a hole in the bottom cover,and the mechanic rebuilding it just knew a cast iron repair wouldn't last so he pumped the entire case full of grease. This one was in the best condition.
Lavoy:
Do you have a pinion? M2362T,16 tooth. Also,I read here somewhere that installing the axle seal is best accomplished with the JD tool. May I borrow yours?
Craig
saving a frozen 420c
parted a 40c to aid the salvage
bought another 420c in search for parts
fully immersed
Post by Lavoy » Fri Jan 27, 2006 9:38 am
Craig,
I have new pinions for sure, maybe a used one.
I will have to check, I think all my tools are loaned out right now, but otherwise yes you can.
homer420c
Post by homer420c » Sun Jan 29, 2006 12:12 pm
I nned a pinion. Every other part appears very ggod. Sell me a good used
(I like the $100 model!) or new. How much is the new? I do need seal tool,so we will just ship when tool is available.
thank you,Craaig
I may recall some discussion of using the sleeve seal repair kit. what is your method for installation?
fully immersed
Post by Lavoy » Sun Jan 29, 2006 8:05 pm
New pinion gears are $100.
You need to use a piece of PVC pipe or a PVC fitting of some sort to get the sleeve all the way on. I use a reducer bushing, but had to open it up a bit on the turning lathe.
Users browsing this forum: No registered users and 252 guests
