not quite there yet on steering clutch
Randy Richards
Post by Randy Richards » Fri Jun 05, 2009 2:59 pm
As you know this a slow process of getting everything to go your way when working on the steering clutches... My question today is "How do I get the dowel pins out the housing that holds the drawbar in place?" Today I managed to get the 4 bolts out that hold the crossmember to the assembly but those stubborn draw bar dowels are stuck good. After I get the round rod for the hanger I 'll be ready to pull the assembly( I think) if it goes half right I think Ill use a engine puller lift to do the lifting, any suggestions so far. [/code]
frozendozer
Post by frozendozer » Fri Jun 05, 2009 3:16 pm
i just pulled the final drive out and the draw bar dropped to the ground
Post by Lavoy » Sat Jun 06, 2009 7:15 am
That's usually the way you do it. If you need to get them out, they are threaded 5/8" coarse on the inside. Thread a bolt in a few turns, and then knock them out with a long punch from the outside.
Randy Richards
final on the bench
Post by Randy Richards » Mon Jun 15, 2009 6:00 pm
WELL it was a good day when you have no cuts, gouges,or smashed fingers or toes. The left side final drive is on the work bench as we speak. All in all it wasn't as dificult as I thought it would be but thats just me talking, for you guys that have done this more than a couple of times it probable old hat to you. Now all that is left to do is tear the guts out of it and then but it all back togother. If some of you have any helpful hints or easier ways to finish this I"M ALL EARS!!! THANK YOU
Randy Richards
1/2 " rod no go
Post by Randy Richards » Mon Jun 15, 2009 6:09 pm
yeah I almost forgot to say the 1/2 " rod used for the hanger was a NO GO the holes weren't big enough and yes I used !/2"..I threw that away and used a tow strap and wrapped it around the bottom of the final and wired the top to the strap and jacked and with the engine hoist and with a few twist and puls it came right out. I don't quite understand the 1/2 " rod deal the only hole that was big enough was a dowel hole on the middle hole on the left.????????????
Post by Lavoy » Tue Jun 16, 2009 9:01 am
The holes are only 7/16" in the final case.
Tractor 850
Post by Tractor 850 » Tue Jun 16, 2009 10:40 am
Yeah, I found that out the hard way as well.
Dave
JD440IC Ser#445235 W/ #63 Dozer
Ford 850 Ser#55497 W/Wagner Loader
fixedforever
Post by fixedforever » Wed Jun 17, 2009 10:06 pm
Randy what kind of machine are you working on?
1010 Gas Crawler sold
2010 diesel crawler loader
Randy Richards
Post by Randy Richards » Thu Jun 18, 2009 6:41 am
I have a 1010 w/ 6 way blade. I know that the post says 40 but I don't know how to change it.
CELSESSER
Post by CELSESSER » Thu Jun 18, 2009 8:47 am
Randy,
That 40 will change to a later and bigger crawler as your number of posts reach certain numbers. Put your type of equipment into the correct place on the personel info page and it will show at the bottom of your posts.
Chuck
Users browsing this forum: Google Adsense [Bot] and 42 guests
