Cracked Block
Cracked Block
Well, more bad news from the machinist today. My 420C block had sleeves in it, machinist said it was funny that they were not pressed in, they seemed to be glued with epoxy or permatex. Well when he bored them out we found out why- water jacket to cyl cracks. So now I need a block to go with the head I already need. The search begins for a 420 block. I am trying to remember, I think 430 and 440 gas are the same as 420?
- JD440ICD2006
I have a very late 420 W. It has the same engine block part number as the 430/440, but the bigger dip stick hole on the right side is not drilled out. The dip stick is on the left side like the older block.
Any one have any idea why JD would do this?
I have had a few, and seen many more, only on high serial number machines. Deere knew that the 430/44 were coming out, and had already developed the block for use on them. Considering that the rest of the block is the same, my guess is when they used up the current stock of 420 blocks, they started using the new casting, and just did not drill them out. You will also find 420's with the late block and the dipstick is machined out. Many times this means a new block has been installed, and the 430/440 block was the replacement block available from Deere. If you look at these blocks, some do not have serial numbers, those I am guessing were new blocks, if it does have a serial number, then I am guessing a used block was installed.
The 440IC parts list calls it AT 10394 T and over in the description is the number T 10474T . I have usually thought the number in the description is possibly the raw casting p/n.
Users browsing this forum: No registered users and 196 guests
