Newbie
cinok
Newbie
Post by cinok » Thu Apr 30, 2009 6:17 am
Just want to say hi to all i recently bought a 450b and did some light clearing then proceeded to try to fix my driveway that is always wet in the spring it is usually somewhat passable but after scraping off the top it turned into a sinkhole and are my new toy I got it pulled out ($$$$$$$) I noticed a hole in the radiator. I have that out and plan on doing the waterpump also and changing all the fluids HYD,TRANs ect and replacing all the rubber hoses that are clamp on and other lines that look real bad. I had it buried nose in up to the top of the rad and the rear over the top of the tracks, can any one think of any thing else that should be done after sticking it this bad.
cinok
Post by cinok » Thu May 14, 2009 10:32 pm
I am putting back together next week If I am missing anything please let me Know
Post by digitup2 » Fri May 15, 2009 7:59 pm
Check to see if you had water over the dipstick if not the old Deere should take that Check any place that isn't water proof that water can get in the housings .Check to see if your steering housings are open or plugged on the bottom it is fine to pull the plugs and open them up but don't go playing in the mud holes without the plugs back in .Digitup.
cinok
Post by cinok » Fri May 15, 2009 9:49 pm
I didnt know plugs need to check tthat thanks
Users browsing this forum: Jim B and 232 guests
