UPDATE Replacing injectors, lines, major tune up on GM 2-53.
frozendozer
Post by frozendozer » Thu Apr 23, 2009 5:03 pm
did the replacement of the i njectors cure your slobber issue's
Post by JD440ICD2006 » Thu Apr 23, 2009 9:40 pm
The new injectors and other work that I did cut down on the slobber. I am told that a little slobber is expected from these.
Just make sure the drain pipes are open so that it does not go in the wrong place.
