JD 1010 Diesel Blade Frame
I have a JD1010 Crawler with blade. The frame for the blade is shot. It's been welded, and there is weld on top of weld... The left side hangs lower than the right side at about 3 to 4 inches so when I go to dig with it the left side obviously digs first making it difficult to do a good job.
Anyone know where I can get a frame for it for a decent price somewhere in NH or VT? Or, how to get the blade to hang level? Thanks.
Roger
1010 Blade
Is this a outside blade or inside blade? PBH in Amherst, N.H should have either one for you, they have a ton of JD crawler parts from what I have been told, need to go there myself sometime. (888-588-3005)
Dan
Dan
Re: 1010 Blade
Dan, thanks for the reply. It's an outside frame.GraderDan wrote:Is this a outside blade or inside blade? PBH in Amherst, N.H should have either one for you, they have a ton of JD crawler parts from what I have been told, need to go there myself sometime. (888-588-3005)
Dan
Roger
